Message 1 of 5
Can't access bt.com through Edge
Hi, for the past 3 days, when I try to access bt.com through my Microsoft Edge browser, it returns with a message '
This page isn't working at the moment
If the problem continues, contact the site owner.
HTTP ERROR 400
I can access other websites through Edge and I can access bt.com through Chrome. It's just the combination of Edge and bt.com that I'm having trouble with.
I've used Edge for years with very few problems, so I don't know why this has suddenly happened.
Has anyone else experienced this issue or does anyone have any idea what is causing this?
Thanks,
Charlie
4 REPLIES 4
Message 2 of 5
Re: Can't access bt.com through Edge
@chasbobby
just tried using Edge and no problems accessing bt.com so maybe your device  try deleting browsing history
Message 3 of 5
Same here, no issues.
Message 4 of 5
Try clearing the history and cookies from your browser and if you are using a "short cut" try using the Email button in the menu bar to the top of this page instead. It could be the short cut is not working correctly.
Message 5 of 5
Thanks guys,
Clearing cookies didn't work, but clearing history did. Back up and running now.
