On the new BT eMail the old drag and drop feature seems to have disappeared.
So can one now drag an email say from the Inbox over to a folder within ones available folders. The only way that I can now do this is to check the email, then go to the Move option on the menu, and select the new folder intowich I want to move the email into etc.
Either I am missing something, or the old feature has been removed. If so can the development team look to re instate this feature . Thank you.
@keja01 The drag and drop feature is still available.
Make sure the target folder is visible in the folder list. Then check (or tick) all the mails you want to drag. Then click on the subject or date and drag the mail/s to the target folder. You should see a square box showing the number of mails selected for moving.
It works. Knew I was doing something silly. Many thanks. And very much appriciated.
