Message 1 of 4
Error Code 553
Please help - I can't send any emails at all as of today. Why is this happening, seems a problem for others too...
3 REPLIES 3
Message 2 of 4
Re: Error Code 553
Hi @Rachel5,
Are you logging in through https://www.bt.com/mail to view your emails? If not, how are you accessing them?
If you're using our website, are you typing your email from scratch or are you copying and pasting data into the email?
DanielS
Message 3 of 4
Re: Error Code 553
Thanks DanielS, I have now sorted the problem, was a vpn issue...
Message 4 of 4
Re: Error Code 553
Hi @Rachel5
Many thanks for posting back to let us know the solution to the problem you were experiencing.  I am glad all is sorted out now 🙂
All the best,
Robbie
