Message 1 of 3
Not receiving Junk email
Hi, can anyone help me? For some time now i am not receiving any junk/trash emails. Those folders are empty, on my app and on the server when accessed via bt.com.
How can this be fixed? I am waiting on a verification email, that i know goes into the junk folder, but if i am not receiving anything in those folders, then i can't see it.
2 REPLIES 2
Anonymous
Not applicable
Message 2 of 3
Re: Not receiving Junk email
@wrighty71
What app do you use to access your mail?
I'm wondering if it is set, (possibly by default), to autodelete Spam as soon as it arrives - which with IMAP email would also delete them from the server.
Message 3 of 3
If you know the email address that you are expecting you could at the address to your "safe senders" list.
Log onto your BTMail account using a browser, not an email client/app, and then click on your username at the right hand side. Select "Settings" then go to the left hand side and select "Mail". Scroll down and click on "Safe Senders" and add the email address then click save.
Also check that the email address and its domain are not in your "Blocked Senders" list which is found in the same way. If either are in the list select them and click "delete"
