Message 11 of 46
Re: SPF
Are you actually a BT broadband customer?
Message 12 of 46
Re: SPF
I do not understand “send via your domain provider’s email server”. As a very long term customer of BT I am quite happy with them and I have no idea what other problems might arrive if I switch for no obvious gain.
Message 13 of 46
Re: SPF
Yes, BT provide email, broadband, landline.
Message 14 of 46
Re: SPF
It's quite simple, instead of sending your domain name email via the BT email servers, simply send them via your domain host's email servers. Otherwise just add the the SPF information to your domain DNS record as posted previously.
Message 15 of 46
Re: SPF
I think th etime has come to give up. What is simple to you completely incomprehensibloe to someone like myself with no technical knowledge whatever. I have no idea what a DNS record is or how to add anything to it. I have no idea whow to send BT email except via BT.
I think gmail people will just have accept some of my emails will not reach them.
Message 16 of 46
Re: SPF
You just need to ask your domain provider to add the SPF details
Message 17 of 46
Re: SPF
As previously explained the domain provider says it is not for them but for the email people.
However, BT have now passed it to their technical people.
Message 18 of 46
Re: SPF
If the problem is the lack of SPF details, it is nothing to do with BT, it is your host that should be implementing the details I posted regardless of what they say.
Who is your domain provider?
Did you actually read the links I posted explaining how SPF works and it's purpose?
Message 19 of 46
Re: SPF
As asked previously, what client (app) are you using to send the emails and how exactly do you have it configured? Are you authenticating the mails with a btinternet email address?
