<p>From 31 October 2024, BT Cloud has <a href="https://www.bt.com/help/broadband/bt-cloud/getting-set-up/download-or-access-files/how-do-i-download-files--folders-and-devices-from-bt-cloud-">closed</a> and all data will soon be deleted.</p>
In the old email system if I clicked in the box above the emails it would select 50 emails. If I click now it either selects 1 or 6 - can you select more than 6 and if so how? Many thanks
