Message 31 of 60
Re: Typing an email cursor keeps moving randomly to start and missing out letters
@DISRUPTED
I'm pretty sure that was a rhetorical question posted by @licquorice and he knows full well what you have posted but you missed out that it also gives full control of the user interface to the ISP and that they can also generate revenue from the placing of adverts.
Message 32 of 60
Still not fixed - happens to me all the time.
Any hope BT? Surely once in a while they must look at this forum.  We are paying for the service after all
Message 33 of 60
The original post about the cursor moving and font changing was March 2024. It is now September and it is still happening. No fix in 6 months? Does anyone know where BT is with this? It's driving me mad!
Message 34 of 60
A further update was due a few months ago but so far it has never materialised however a request as per this thread
Webmail Update - Release Date? - BT Community
for any update on when the update to update the update has be sought so hopefully this will happen at some point.
Meanwhile I would suggest that you install an email client/app such as the free Thunderbird email client on to your PC/Laptop and use that. If you do that all the problems you have/are having with "new" BTMail user interface will disappear.
If you already use an email app on a mobile device you will know the benefits of an email client as against a web browser to access your BTMail.
Message 35 of 60
" install an email client/app... and use that.  ...all the problems you have...will disappear. "
Welcome to another in the series of "Broken Britain" threads.
Press 1 to listen to an alternative message
Press 2 to join an indeterminate queue
Press 3 to listen to an never ending worn-out musak tape loop
Press 4 to be connected to overflowing voice mail box
Press 5 to to be automatically disconnected after a random wait
Press 6 for silence
Press 7 to be mis-directed
Press 8 to give up
Press 9 to hear this message again
Message 36 of 60
i had same situation- Jake support team fixed it simple- Log into your BT Mail account.
Click on View in the menu bar at the right-hand side near the top.
Single click Conversation View to toggle it on or off which should turn it from purple which is on to black which is off.
i can also view all historic emails easier now in inbox
Message 37 of 60
Thanks, I've had a look and Conversation view is already off (in black). I may have to use another email programme as has been suggested by others, but I'm not very tech savvy so a bit worried about doing that. I can't understand why BT can't just get it to work!
Message 38 of 60
try again, log back in, and reset it, again mine played up again, but when logging back in and turning it off, it worked. so you may need to try a few times, good luck
Message 39 of 60
I will! Thank you for taking the time to help me!
Message 40 of 60
So where's the connection between the issue and this view option? Jake?
