Message 51 of 60
Re: Typing an email cursor keeps moving randomly to start and missing out letters
Being pedantic, it is IMAP not EMAP!
Now a days in the 21st century it is the users choice whether to use POP3 or IMAP.
If you are moving from POP3 to IMAP it is advised to check that your emails are still on the server so that they will be available when you move to IMAP.
If they are not there you should back them up before setting the account up as an IMAP account then move them to the IMAP folder structure.
It is not rocket science and there is plenty information on the Internet how to do that.
Message 52 of 60
Apols., error of thought. IMAP then.
Mail client historical downloaded emails over 20+ years not necessarily retained on server(s), typically not with POP - not even sure they would be regardless. Changing (some? all?) clients from POP to IMAP may/will 'lose' historical entries.
Message 53 of 60
That is why it is recommended to check and or do a back up before changing!!
Message 54 of 60
POP3 emails are downloaded to the client and unless the option is ticked, they are not retained on the server.
It is therefore incumbent on the customer to ensure that POP3 data files are regularly backed up and retained.
Message 55 of 60
But no point / need if already aware of an issue. (But not everyone might be or has the ability to research - and we are going way off topic now...)
Message 56 of 60
Quite so, which is why switching from POP to IMAP can be a non-starter.
Message 57 of 60
I fail to follow the logic.
If the customer hasn't saved the files, they don't exist anyway so how does moving to IMAP change anything?
Message 58 of 60
They are "saved" insofar as they are held by the client operated as POP. Charging to IMAP may / will change the structure so they are (or may be) lost.
Message 59 of 60
I am finding that you have very little knowledge when it comes to POP3 or IMAP and are basically looking for problems that are not there. I am therefore not going to waste any more of my time responding to this.
Message 60 of 60
Thank you.
