Message 1 of 2
calendar reminder cannot be opened, it appears for a split second then closes. New font is not good.
Had this issue last week, which was only applicable to Google.
 E-mail font change which is not very easy on the eye, and also you cannot open e-mail reminders.
BT fixed this last week, but now it is back again.
1 REPLY 1
Message 2 of 2
Re: calendar reminder cannot be opened, it appears for a split second then closes. New font is no...
Hi @lawrence75
Thanks for coming back to the community 🙂
What happens when you try and open reminders?
The Solved: Bt Email font changes - BT Community thread has advice on the BT font changes.
Thanks 🙂
Leanne.
