Message 1 of 3
emails stuck in Outbox
Hi, I have emails stuck in my outbox on my iPad, but not showing on my iphone or laptop. They system is stuck on one email with the wheel continually turning and no option to delete or resend. Ive looked on this community page and tried the option of going into settings and all seems to be ok. Its not all my emails but most, any advice? thank you
2 REPLIES 2
Message 2 of 3
Re: emails stuck in Outbox
How are you accessing the emails on your iPad. Is it with a web browser or are you using an email app and if so which one?
Are you still able to use the Internet on your iPad?
If it is an email app that you are using you could initially try disconnecting your iPad from your wireless connection to see if this allows you to delete the email from the outbox. To do that you just need to put the iPad into Airplane Mode.
Message 3 of 3
Hi, thank you. but hasn't worked, I am using the app, so going to and delete and re apply. I think it is one email which is 'stuck' trying to open. Ive had problems with bt mail since they changed from Yahoo,!!
