Today I got an email saying Impending closure of my email address. If I wanted to keep it I had to click on my email address included in the email and complete the form. Stupidly I clicked .. There was no form or anything else so I deleted the email. Should I be worried ..Very scared granny help
Solved! Go to Solution.
It is a scam. As long as you never entered any information and as long as the link did not cause anything to be downloaded onto your device you should be ok.
To be on the safe side run a full virus scan and it may be best if you keep an eye on things such as online banking if you use that. You should also consider changing your email password.
In future be aware that BT will never ask you to update your account. You should not click on any links in unsolicited emails especially if they want you to verify anything such as email accounts or bank accounts.
Thank you for the help
