Message 1 of 4
Annoying BT Email Check Box
Can BT do something about the 'non-voluntary' annoying check box tick that keeps appearing against email messages when I don't want it to. A few times now, I have inadvertently deleted messages where a tick has suddenly appeared  just because it is either the first message or the one I just looked at etc. It never used to be like this and has been happening for about a year now. A tick should appear only when I decide it does not the system. Thanks for any input.
Tags (1)
3 REPLIES 3
Message 2 of 4
Re: Annoying BT Email Check Box
You should look at your email account settings.
To do that log onto your email account using a web browser then click on your username at the right hand side. Click on settings then go to "Mail" in the left hand column then check if the box " View next mail after delete / move" is ticked.
If it is ticked untick it and click "Save".
Message 3 of 4
Well @gg30340 That appears to have done the trick! If only it was more apparent from the settings description. Many thanks for this and I hope others will notice it too.
Message 4 of 4
Thanks for your post about the annoying tick & to Distinguished Sage for his solution.I had just accepted it as part of the email setup.It was so damned annoying.Like you i had deleted em when forgetting about a box being ticked.
Cliff
