Message 1 of 3
Auto-reply banner
Hello all,
I wanted to set up an auto-reply which I did.
I then went back to my emails and every time they refreshed, a message in a yellow oblong banner appears to say that 'Your auto-reply setting has been enabled or changed'.
This is frustrating since it appears all the time and needs closing before an email can be read properly.
I went back to disable the auto-reply in the hope the yellow banner would disappear, but it's still there doing the same thing and not showing any sign of stopping.
Can anyone advise on how to stop this?
With thanks,
Darren
2 REPLIES 2
Message 2 of 3
Re: Auto-reply banner
It is a security banner that gets set up automatically when you change anything in the settings so that you are made aware of the change per chance your account had been hacked and you were unaware that changes had been made.
You can not turn it off, otherwise the hackers could also do that, but it will turn off automatically after a few days.
Message 3 of 3
Thanks for your information - that's much appreciated.
Darren
