Message 1 of 2
BT MAIL - Repeating Words?
On replying to mails, every word I type is repeated, as soon as I tap the space bar! If it's a xase of having to delete the app & re-install, will I get all my folders back?
Example:
HiHi
ThankThank youyou forfor youryour replyreply
1 REPLY 1
Message 2 of 2
Re: BT MAIL - Repeating Words?
The BTMail app is not a very good product in many people's opinion so if you are using the BTMail app the best advice is to delete it and install a better email app such as Bluemail or use the email app that is pre installed on your device.
