Message 11 of 14
Re: BT Mail - login loop
@joesoap007
What happens if you use this link?
BTMail
If it takes you directly to the BTMail logon page use it to make a desktop shortcut and use that in future.
Message 12 of 14
Thanks, sorry missed this suggestion. Sadly it has not helped. I thought this was fixed some weeks ago but the issue has returned and I am brassed off with having to constantly go into In Private Window and enter log in details twice.
Message 13 of 14
Try the following to see if it helps.
Log onto your BTMail email account using a browser.
Once logged on and on the main email page with the list of emails, go to the webpage address bar and save it as favourite.
Log out of your email account and close the browser.
Open the browser and click on the BTMail favourite that you have just made. This should take you to the log on page.
Log on as normal.
Message 14 of 14
Thank you gg30340, your route and guidance has solved the problem.
