Message 1 of 7
BTCONNECT email
I have a btconnect.com email address.   Using Windows Live Mail on a windows 7 laptop, and also a windows 10 desktop.  The laptop has stopped sending, but still receives ok. The desktop still works both ways. Have tried different settings in the outgoing smtp server, but to no avail.
Help please.
John W.
6 REPLIES 6
Message 2 of 7
Re: BTCONNECT email
This is the BT residential forum, as a business customer, you need to post on the business forum.
Message 3 of 7
Re: BTCONNECT email
Help please.
John W.
@johnnyx49
That is a BT Business email address.
Please post on the BT Business forum.
https://business.forums.bt.com/
This is the BT Residential forum.
Message 4 of 7
Re: BTCONNECT email
Deleted.
Beaten by others with same question
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
Message 5 of 7
Re: BTCONNECT email
Hi, this is an address I've had from way back when, now retired (10 years) and residential.
Message 6 of 7
Re: BTCONNECT email
BT Connect addresses are business addresses, not residential. There is no expertise on this forum with regard to BT Connect.
Message 7 of 7
Re: BTCONNECT email
OK
