Message 11 of 12
Re: BTInternet DMARC record
As long as it works, don't worry about it. It not a question of your security, it just a means of verifying that you are who you say you are.
Message 12 of 12
I use Ionos (1and1), they only charge £6/m for domain, webspace and multiple email addresses with access to their SMTP server.
