Message 1 of 10
BY Mail, freezing and cursor moving
Within the last week my email has changed for the worse.
Using a laptop
It is taking much longer to open up when first logging in.
Some email addresses are no longer recognized and invalid.
When typing the cursor freezes and eventually appears at the beginning of the email. looks like it is happening when auto save is processing.
Any ideas?
9 REPLIES 9
Message 2 of 10
Re: BY Mail, freezing and cursor moving
Stop using webmail and use the proper tool for the job, a mail client
Message 3 of 10
If you are using a web browser and your email web page has recently been updated try clearing your web browsers history and cookies.
Message 4 of 10
Same for me.  Replying to an email is now not possible. Did you have any luck?
Message 5 of 10
 @licquorice  really helpful 🙄
Message 6 of 10
Perhaps if you tried it you would realise that it is.
Message 7 of 10
the original poster asked for help with web mail your comment was irrelevant and unhelpful, you know the saying about not having anything nice to say same applies to being helpful
Message 8 of 10
@Tappets
go into the settings and click on "Mail" and change the "Auto save draft" time to five minutes to see if that helps.
Remember to click "Save".
At least it will give you more time to complete your email and send it, its definitely a problem with auto save
if you look at a saved mail after a crash its in HTML not text
HTH
Message 9 of 10
Given there is nothing I can do about webmail, the advice was neither irrelevant or unhelpful. Why would you drive a smelly clapped out Trabant when you could drive a Ferrari for free.
Message 10 of 10
@licquorice
I have neither the time or patience to explain if you don't understand 🙄
