Message 1 of 4
Backup of an individual folder
is it possible to backup an individual folder?
3 REPLIES 3
Message 2 of 4
Re: Backup of an individual folder
More information required. What is the folder, is it computer folder  or an email folder etc. Is it to back it up to a computer, BT Cloud or some other system?
Tags (1)
Message 3 of 4
Thank you for your reply. What I want to do is take an email folder and back it up to my computer.
Message 4 of 4
You can not do that with the folders in BTMail when using webmail (using a browser) however if you installed an email client such as Bluemail or Thunderbird as an IMAP account, which replicates the folders in your BTMail account you can then use the email client to back up your email folders to your computer.
See links about Bluemail and Thunderbird. It may look a bit involved but it is fairly straight forward if you follow the help pages.
BlueMail Help - Help Center for BlueMail
Thunderbird — Make Email Easier. — Thunderbird
