Message 1 of 1
Bank Rate Down : Indecipherable New Rates Text.
FWIW.
My I/C email from my Savings Provider, doesn't display properly. The Old/New rates are indecipherable, probably, a '.png'. I've checked all my settings, nothing obvious. Crunching through the email pages; just populating boxes, to see the results, then revert.  I came up with a local 'fix'. So, if you're experience this sort of issue, give it a try ?
If you take a look at the options-bar 'FORWARD' has 2-choices, 'Attachment/Inline'. Use the 'Inline' selection. The 'FORWARD' window appears, and the page displays correctly. Once you've used the info, for whatever. Close, as many screens, as you like. Alternatively, log-out.ELVIS HAS LEFT THE BUILDING !ELVIS HAS LEFT THE BUILDING !
