Message 1 of 6
Blocked domains
How can I check the list of domains that I have blocked and unblock a domain that I have blocked in error, please?
5 REPLIES 5
Message 2 of 6
Re: Blocked domains
@Haz1 You'll need to:
sign in to BT  Webmail on your favourite browser
click your name in the top right corner
click settings from the drop-down menu
click Mail on the left of the screen
click Blocked senders from the list
you'll see all your blocked senders and domains, click the dustbin icon by the one you want to delete
Hope this helps
Message 3 of 6
Re: Blocked domains
Thanks. This did the trick.
Message 4 of 6
Re: Blocked domains
That was the case until recently but now the blocking options have disappeared
Message 5 of 6
Re: Blocked domains
I have just checked and all the blocking options are still there.
You can do it via your email settings or selecting the email in your list and using the "more" button in the menu bar.
Message 6 of 6
Re: Blocked domains
Thanks for speedy reply but i get dozens of bad emails and the 'more' option used to act in-bloc but now only per each email.
Settings does not help.
