Message 1 of 3
Blocked senders list
How do I remove someone from my blocked senders list as accidentally put it in
2 REPLIES 2
Message 2 of 3
Re: Blocked senders list
Just highlight the entry and delete it
Message 3 of 3
Log onto your BTMail account using a browser, not an email client/app, and then click on your username at the right hand side. Select "Settings" then go to the left hand side and select "Mail". Scroll down and click on "Blocked Senders". Scroll down the list until you find the one you want to unblock and select it. Click on "delete".
