Message 11 of 45
Re: Bt Email font changes
This happened overnight .... and, yes, it is difficult to read my emails now. The new font is not user friendly and I am unsure as to whether BT per ce actually reached out to its customers to discuss this new font - and if not, who chose it!!!!!  It is dreadfully difficult to read emails now.....and, no, havent found a way of changing back - is there a way anyone??
Message 12 of 45
It's the browsers falling back to a different font as the style sheet that's being requested by the JavaScript within the website is causing a CORS error as the requesting origin is not in the allowed list.
Once the requesting origin is added to the allowed list the BT font should be loaded correctly.
For security reasons browsers will block cross-origin HTTP requests made from scripts that are not specifically allowed.
https://developer.mozilla.org/en-US/docs/Web/HTTP/CORS
Message 13 of 45
Re: Changing the display font on the email web interface
Everyone has the same question but answer came there none! The change seems to have happened on Chrome but not on Edge. Is this significant? Totally infuriating!
Message 14 of 45
The Distinguished Guru was posting an answer at the same time as me. Trouble is, I don't understand it! It seems to suggest the problem will sort itself out, though. I hope so!
Message 15 of 45
@SteveB21
Essentially once BT have fixed the CORS issue the original BT fonts should load correctly and the browser should render the font correctly.
As to why it may be ok in another browser compared to in chrome. Could be down to chrome implementing a stricter CORS policy or even the resources are cached.
Message 16 of 45
Firefox wont load it at all!  Saying BT have problems?!
Message 17 of 45
So I have had a look, and further to Distinguished Guru's comment had a look at the browser settings for websites etc. Seems Firefox and MS Edge are preset for Times New Roman.
In fire fox you goto, Tools/Settings/General/Fonts and can change the defaults there.
In MS Edge goto, Settings/Apperance/Fonts and change it there.
This seems to have worked for me 😀
Message 18 of 45
Thanks Natasha. I use Chrome but following your logic found the settings and appearance from which I have successfully managed to change the font and font size. Good luck everyone.
Message 19 of 45
YES!! Well done!
Thank you.
I've now gone for Helvetica.
Message 20 of 45
Hey @ParkBVP.
Welcome to the community.
If you take a look at this community page: Solved: Bt Email font changes - Page 2 - BT Community. There's some really helpful information which could help.
Let me know how you get on.
Debbie 🙂
