Message 21 of 45
Re: Bt Email font changes
You learn something new every day, thanks.
Done the same in Chrome!
Settings/Appearance/Customise Fonts
Message 22 of 45
Re: Changing the display font on the email web interface
Thanks Debbie. It worked for me - I have cahanged the default font settings in Firefox. I remember doing this originally but perhaps it resets at some Firefox updates.
Keith
Message 23 of 45
This solution worked for me - thanks for the advice.
Message 24 of 45
Thank you - this worked for me.  Really grateful....
Message 25 of 45
I use Chrome and cannot find any Appearance in Settings. (Oops! See following comment!)
Message 26 of 45
As you were! I was looking in BT Mail settings. Yes, changing the font in Chrome settings works.
Message 27 of 45
What was the original font yesterday?
Message 28 of 45
Puma937,
It was a mixture of fonts but Times New Roman was the most noticeable change making it harder to read sections of the email system and even these community pages.
Message 29 of 45
How do I fix this in Safari on iMac please ?
Message 30 of 45
Try this:
  1. Select the Safari menu, then select Preferences.
  2. Select Appearance, which should be the second option on the right.
  3. Under Standard font, select the Select button. Choose your desired font type, size and colour.
  4. Click OK on the Preferences screen.
Fingers crossed!
