Message 41 of 45
Re: Bt Email font changes
ok so how do I fix this issue when using Safari pls?
Message 42 of 45
Did you read all the thread. The answer is in there.
Message 43 of 45
Where is preferences on the Safari menu. I can see settings but there is no appearance
Message 44 of 45
I can see the post regarding Safari but it doesn’t make any sense - where is preferences on the Safari menu?
Message 45 of 45
Good morning @dmhelsby, welcome back to the BT Community.
Each browser is slightly different in its options and setting, but is it via a Mac that you're using Safari, or is it an iPhone / iPad?
For the desktop version on a Mac, I've found this thread on Apple's Community that says preferences should be under the Safari option at the top of the screen.
Peter
