Message 1 of 7
Bt internet emails
I am abroad and my emails won’t load via wifi or otherwise ! Account error with mail server  mail.btinternet.com not responding !
6 REPLIES 6
Message 2 of 7
Re: Bt internet emails
Which country are you in?
How are you accessing your email account, is it with a web browser or are you using an email client/app?
Are you using a VPN, if so try turning it off.
Message 3 of 7
I’m in Germany and accessing using the Bt internet.com settings
incoking outgoing smtp ssl
incoming  port 993
port 465 for outgoing mail
Message 4 of 7
If you are using those settings it means you must be using either an email client or email app.
Have you tried using a web browser to log onto your email account that way to see if it works?
BTMail
What device are you using?
Are you using a VPN on your device?
Message 5 of 7
No vpn. Still not working and back in Uk now .
if I go through the website  emailbt.com I can see the messages of the last few days
Message 6 of 7
I’m using iPhone X
Message 7 of 7
Solved by deleting account in apple
Mail app and reinstating . Told
It’s probably an iOS update that updates some settings . But to me they looked the same . However it’s fixed
