Message 1 of 22
Can't access older emails
As of yesterday, I can no longer scroll down to emails more than a few days old.
This means I cannot access a health critical email.
I haven't changed any settings.
What is going on?
21 REPLIES 21
Message 2 of 22
Re: Can't access older emails
I have exactly the same issue, that is if I can get in to the inbox now due to constant loop back to the "there's been a problem logging in page". What is going on lately? I am on an old talk21 email and seriously this used to be so good to use. You could log in quickly and emails would be there. And deleting emails was a doddle as well. Just select and press down and it would allow to you rapidly scroll. Now it is a joke. Click and hold select and then individually tap the arrow down and then click the last email you want before deleting. Why so much more difficult these days?!!!!!!
Message 3 of 22
I have exactly the same problem.  There is no down arrow to click in the bottom  right hand side of the screen.    I can read only two or three days' emails.  I have a btopenworld account.   It does say on the left I have used 6 GB
Message 4 of 22
I have the same issue which occurred from Monday 3 July. With some difficulty I can access older emails on my Samsung phone but not on my laptop. Any ideas how to solve this? Thanks
Message 5 of 22
If you have not already tried it make sure you don't have "Conversation" view selected in the "View" settings on the right hand side. You can toggle it on/off by a single click.
Message 6 of 22
I don't have 'conversation' tag highlighted. Tried the 'view' solution - doesn't change the inbox emails on display.
Message 7 of 22
Have accessed 'sent' emails and found various contacts; then put names into 'Search in inbox' tag and the emails show up in inbox under an 'older' heading. Pretty stupid way to find stuff, methinks!!
Message 8 of 22
Grasping at straws.....In the settings have you tried ticking or unticking the box  "Inbox sorting"
Message 9 of 22
As if by magic, emails have returned! Hey ho!
Message 10 of 22
Was that without doing anything?
