Message 1 of 26
Can't login to BT email from Thunderbird running in Zorin on my laptop
Hi
I can't login to one of my standard BT emails using Thunderbird running in Zorin on my laptop getting the message "Unable to log in at server. Probably wrong configuration, username or password".
The username and password are correct as I can log in to the email account using a browser on the laptop!
Something is broken with BT email and third party email client apps as my daughter migrated my wife's iPhone to a new one yesterday and tried to to connect using the migrated Outlook app but got the same error message as above. She then downloaded the BT mail app to the new iPhone and successfully connected it my wife's BT email!!
On my Samsung S10+ phone I have the Bluemail app successfully accessing 4 BT email addresses which was set up a long time ago!
Something is wrong with BT's email and 3rd party email clients trying to access it!
Paul
25 REPLIES 25
Message 2 of 26
Re: Can't login to BT email from Thunderbird running in Zorin on my laptop
are you currently a BT broadband customer or do you pay for premium email?
have you tried to log in to email using browser on laptop instead of app?
Message 3 of 26
I have BT broadband and I have had it since I retired from BT in 2013
These are all standard emails.
Paul
Message 4 of 26
I said in my original post that I was able to log in successfully using using a web page so the email and password are correct.
Paul
Message 5 of 26
My daughter just reminded me that the Outlook mail app transferred from my wife's old iPhone to her new iPhone failed as also did the Apple mail client that comes with the new iPhone.
When my daughter downloaded and installed the BT mail app on the new iPhone it worked!
There is definitely an issue with the current BT mail and 3rd party mail apps which didn't exist in the past!!
Paul
Message 6 of 26
I don't have any problems accessing my BT mail using thunderbird on my pc and using bluemail on my Samsung mobile
Message 7 of 26
As long as the settings are correct, BT email servers have no knowledge of what client is accessing the account.
I have no problem with Thunderbird, MS Outlook and Blue Mail on various devices and operating systems.
Message 8 of 26
I also have no problems accessing my BT mail using various mail clients but these were all set up some time ago!
Message 9 of 26
Well I've just created a new btinternet account on Thunderbird with no problem.
Message 10 of 26
Following your post about successfully creating a mail account in Thunderbird I did some further investigation today.
I have two BT email accounts and my wife has two.
Deleted my account in Thunderbird and recreated it with no problems!
I have found that there is no problem creating either of my mail accounts in Thunderbird but trying to create either of my wife's mail accounts fail!
BTW, my wife's BT email accounts have a different password to mine.
Any ideas what could be the problem?
Paul
