Just to check with this one, @masonpen and @bluedoo62 - have you checked the spam / junk folder to ensure that the Temu emails aren't being received there?
On initial investigation at our end, emails from Temu are regularly being received, and as a well known service this isn't something we would proactively block.
Peter
Thank you, it would be great if it could be resolved
Hi
checked spam/junk folders , nothing in there
when I go into Temu app it comes up a message saying where having trouble sending emails to you and to verify email is correct which it is
Thanks, @bluedoo62, have you got it set as @btinternet.com, or @btopenworld.com?
It may be worth trying the other option to see if this works.
Peter
Yes the email is correct @btinternet.com
Yes I’ve checked all spam and junk boxes..nothing in there, as mentioned I buy from Temu so often that I’d be inundated with messages, but nothing received.
Just an update on this one, following some more checks our team aren't noticing any delivery issues from Temu and it still seems to be potential issues from their end.
They're also recommending that users try switching to the btopenworld domain in their email contact to see if this makes any difference.
Peter
have contacted Temu on the chat but they don’t seem to grasp the problem
how do you change to email to btopenworld domain
Btopenworld and btinternet are interchangeable. Just change your contact details for Temu to btopenworld
Hi
i I changed my email address in Temu and had them resend my last order confirmation and it came through ok
so will keep an eye on it
thanks
