Message 1 of 4
Changing Names of Folders
System won't accept amending names of folders. Is there a way of doing this that I'm unaware of please?
3 REPLIES 3
Message 2 of 4
Re: Changing Names of Folders
You can only change the name of folders that you have created, you can't change the name of 'system' folders such as 'Inbox' etc.
Otherwise, simply create a new folder with the new name, drag and drop the contents of the old folder and then delete it.
Message 3 of 4
Try hitting Enter once you've entered the new name.
Message 4 of 4
Result! Thank you.
