Message 1 of 5
Email Folder count
P[ease advise if I can have an email count to the volume of emails in my many folders and also a total count?
4 REPLIES 4
Message 2 of 5
Re: Email Folder count
Hi Alan, BT Mail doesn't currently display a total count of emails across all folders in one place, but you can view the message count for each individual folder by opening it—most folders show the number of emails in the top bar. For a full count, you’d need to manually add up each folder’s total or use a mail client like Outlook or Thunderbird, which can sync with your BT account and display combined folder statistics.
Message 3 of 5
You can not get a combined total of the contents of all emails within all your folder but you can get the number of emails contained within each folder by hovering your mouse over the folder's name in the folders list.
Message 4 of 5
Thank you for your speedy response
Message 5 of 5
Thanks for your speedy response I guessed that would be the outcome 👍
