Message 1 of 5
Compose Problem
I have No where to wright on the compose page, the space where you wright was less than 1/2 cm  after they changed to the new format, now it's non excitant, Does anybody know how to fix this,
It's on my Laptop windows 10
Many thanks in anticipation
4 REPLIES 4
Message 2 of 5
Re: Compose Problem
Hi @Selina1
Welcome to the community. 🙂
If you change the zoom on your laptop, does the box appear or look larger?
Chris
Message 3 of 5
Re: Compose Problem
Hi Thanks for your reply,  I have just got in touch with BT and it would seem the problem is their end not mine, Many thanks
Message 4 of 5
Re: Compose Problem
Hi Chris, thanks for your reply, in the end I had to contact BT and it seem's it was their end not mine,all fixed now took 2 days to fix.
Many thanks Sandra
Message 5 of 5
Re: Compose Problem
Morning @Selina1
Thanks for coming back and letting us know.
Glad to read this is now fixed for you.
Leanne.
