Message 1 of 4
DRAFT emails header has changed to FROM
Seemingly since latest webmail version 3.9.0.2 in last few days, when listing DRAFT emails the first column is now showing FROM . . . which obviously shows my name! Do not know how to change this to "TO" as it has always been previously.
3 REPLIES 3
Message 2 of 4
Re: DRAFT emails header has changed to FROM
Hi @PeteTH
I've sent you a private message to get a bit more information about this from you. Hopefully, I can get you some help with it.
Chris
Message 3 of 4
This is another brilliant idea from programmers who don't use email and don't test the effect of their changes on users. If, like me, you have a 'View' set to NONE, you will get this problem. The only way to see the Draft folder with a 'To' is to change the 'View' to 'Right', and then change back to 'None' for your Inbox.  Thank you BT.
If it helps, fortunately, they didn't mess with the mobile app, so the Draft emails still show the 'To'
Message 4 of 4
New webmail version showing in Edge browser in last couple of days = MX_3.10.0.2: this is SO much quicker at loading - speed seems back to the old days! BUT, "DRAFT emails header has changed to FROM" issue still remains.
