Message 1 of 4
Deleted emails
I have deleted an email by mistake and i cannot retrieve it. I tried the messaging help bot but that was a waste of time
3 REPLIES 3
Message 2 of 4
Re: Deleted emails
If it isn't in your trash folder (which it should be if you have only just deleted it) it is gone permanently and can't be recovered.
Message 3 of 4
Re: Deleted emails
If you log onto your BTMail account using a browser (Webmail) and the deleted email is not in your trash folder it means that it can not be recovered and is gone for good.
Message 4 of 4
Re: Deleted emails
Thank you I feared that was the answer
John
