I don't know what is happening to some of our emails.
Yesterday we got a response to a complaint I made, my husband read it but when I came to look today it's not there.
I checked the 'Trash' folder in case it ended up there and although there are other messages from Sunday, this one isn't there. This is not the first time this has happened - I can see my sent message also but it isn't linking to the reply sent by the company I contacted.
Can anyone help me with this because the official BT Help is a bot that just goes around and around in circles, going nowhere and it frustrating rather than helpful. 😥
Solved! Go to Solution.
Make sure that the "Conversation" View is not active. To do that log onto your BTMail account and click on "View" in the menu bar at the right hand side. Scroll down and Single click "conversation view" to toggle it on or off.
When you toggle it on or off you will see the name "Conversation View" change colour from grey to blue when it is turned on.
If you are accessing mail on multiple devices, make sure none are configured as POP3 rather than IMAP. If one is and the box hasn't been ticked to leave a copy of the message on the server, the mail will be downloaded to that device and then deleted from the server hence not visible on any other devices.
That doesn't apply if you only use webmail.
Hi @RuthL0VE
Welcome to the community.
I have fed your issue back to our email support team, if they require any extra details I will be in touch.
Thank you for your patience.
Ritu
