Message 31 of 38
Re: Email Loading Issues On Webmail + Clients
Hello @Rach_H,
The issue has resurfaced. Could you or someone else kindly look into what is going on this time?
Tags (3)
Message 32 of 38
@licquorice
The problem affecting WebMail also impacts email clients accessing via IMAP. See the previous posts.
Tags (3)
Message 33 of 38
@licquoricewrote:
Is your browser configured to clear cookies on exit?
No.
Still getting passcode demands today.
Message 34 of 38
Do you have 2-factor authorisation activated on your account @DISRUPTED? If you disable this then this should stop happening.
Rach
Message 35 of 38
Rach
Unless I am mistaken, BT made 2FA obligatory and it can not be turned off by the customer.
2FA however should not "kick in" when using an email client or app due to the way email clients and apps work.
Message 36 of 38
@gg30340
You are correct, once 2SA is setup in My BT it cannot be turned off.
The system may take a couple of weeks to learn what devices are normal for the customer.
Ali
Message 37 of 38
@Ali_A
Thanks for confirming.  I was aware of that but given how BT work it would not have surprised me if they had rescinded that and allowed users to turn it off.
As regards the way devices are "trusted" after a few weeks this seems to be very hit or miss and not at all a given that a device will be trusted after period of time.
Message 38 of 38
Ali
Ali, in my case this has been going on for months, not weeks! Initially it did not recognise the single device (PC) used for webmail access for 2-3 months, then it suddenly did for around a month, then it equally suddenly reset to where it didn't again and it's remained that way for the past 2-3 months and remains ongoing.
Why is that please and how can it be resolved?
