Message 1 of 4
Email Login
My email has recently started using 2 factor authentication, sending me a text code for input on login. How do I disable this?
3 REPLIES 3
Message 2 of 4
Re: Email Login
You can't. It is now compulsory.
Message 3 of 4
Re: Email Login
OK Thanks - quite annoying!
Message 4 of 4
Re: Email Login
It is more annoying if your email account gets hacked!
