Message 1 of 4
Email Safe List
In Edge how do I add an email address to the safe list?
3 REPLIES 3
Message 2 of 4
Re: Email Safe List
The same way that you do with any other browser, it's not browser specific.
Click on your username (email address) in the top right corner and select settings and then select mail in the left hand pane for various options.
Message 3 of 4
Re: Email Safe List
If you have received an email and you want to mark it as a "Safe Sender",  in the list of your received emails you just need to tick the box to the left of the email address in the list then select "Safe Sender" in the menu bar at the top of the list.
If you have not received an email but you do know the email address that you want to mark as a "safe sender" Log onto your BTMail account then click on your username at the right hand side. Select "Settings" then go to the left hand side and select "Mail". Scroll down and click on "Safe Senders" and enter the email address into the box and click "Save".
Message 4 of 4
Re: Email Safe List
Thank You....your second paragraph solved the problem.
