Message 11 of 12
Re: Email Upgrade
It looks the same, if you're using an app on the ipad to access your emails it looks like an update for that? How often do you check for app updates as it'll show for efinite in the relevant store
Message 12 of 12
Re: Email Upgrade
Yes - I’ve updated the app, so no more pop-up! Thanks Gary
