Message 41 of 74
Re: Email account under attack
The 46050 guesses is based on the number always changing after each guess. Otherwise it would be even easier.
Message 42 of 74
I guess you didn't read my post 23
Message 43 of 74
I did read it. You seem to make 2 points. The first was to limit the amount of guesses before being locked out, while the other was based on the likelihood of people being able to guess the number. I responded to the second part. I do agree that it would be a good idea to lock out the hacker after a few attempts. We made a similar suggestion to BT a few days ago.
Message 44 of 74
The point I made is the number of guesses is not pre-determined as you suggest if not all the numbers are used.
Message 45 of 74
Hey?  Assuming they use every number between 0 and 9,  from 0000 to 9999, that's 10x10x10x10 combinations or 10,000!
Message 46 of 74
Thanks for clarifying. The fact that not all numbers would be used makes no difference, as you make random guesses. If anything, it could make things easier depending on how this is determined, but certainly not more difficult. You would guaranteed have a 99% chance to guess the correct number after 46050 guesses. Obviously these guesses should not all the time be the same number.
Message 47 of 74
But as I keep saying, unless all all combinations are used, it's not that simple. You could keep hammering the same number for 10,000 times but if it isn't used you won't get in.
Message 48 of 74
@ZakMcKracken
This is how it works.
If the same number is used every time the hacker just tried every number until they get in.
If a different number is used every time the hacker  uses the same number every time until they get in.
If not all the numbers are used, neither approaches work.
Message 49 of 74
You simply don't pick the same number 10000 times, but make random guesses.
Message 50 of 74
Exactly, random guesses are not a pre determined number and are extremely unlikely to strike gold.
