Message 11 of 13
Re: Email history and folders disappeared
Thank you all for your input. For clarity, I was using MS Outlook as a mail client to access my btinternet.com messages. When I log into btinternet web mail I can't see any older messages, so I think they're all gone, but I'll be happy to try any suggestions.
Thanks again,
James
Message 12 of 13
I'm assuming you don't have a backup of your SSD anywhere, if you do the mails will be in a .PST file.
Message 13 of 13
Are you sure that the SSD has died ? It could be something else that is causing the SSD not to "fire" up.
I would be inclined to remove it from your PC and connect it to an SSD hard drive enclosure. You can buy one on Amazon for about £10.
Assuming the SSD is not broken, this would allow you to place your SSD into it and then connect it by USB to your PC or laptop. You would then be able to search through all the files that are on it and locate Outlook's PST and copy it onto your PC or Laptops drive and access it from there.
