Message 61 of 92
Re: Email not syncing on Android
It will work until you send or forward an email, then it will stop again. Uninstall Gmail updates and revert to 'stock' version
Message 62 of 92
Uninstall Gmail updates and revert to version that came with Android
Message 63 of 92
Email not synching on Android phone
Like many I'm unable to send or receive emails on my android phone since the 4th August.  I can get them on my computer.
Message 64 of 92
Re: Email not synching on Android phone
Found this in the comments on the Gmail app
Message 65 of 92
There is a new version of Gmail been released.
This doesn't seem to fix the issue.
Not sure if deleting sent or forwarded emails still works as some of the ones I get sent I need to keep and can't delete. I guess I could send them to myself...
Rubbish experience - I wonder if any of the other big USPS such as Sky are having similar issues?
Message 66 of 92
Have just done this, as having same problems .....
Seems to be working for now.
but reading the forum lots of people having same problem in last few days.
Uninstall gmail then reinstall worked for me Fingers crossed.
Message 67 of 92
I have followed the advice of deleting my BT account and then adding it again and it worked.
Message 68 of 92
I've just deleted my BT account from Gmail after I've updated the Gmail app. Then added it back in. Seems to have pulled some additional emails in that weren't delivered before.
I'll monitor to see if this continues.
Message 69 of 92
Re: Email not synching on Android phone - NOT just GMAIL related
This is not isolated to Gmail. iPhones/iPads/PCs still work. This is how BT currently works (or doesn't) with Android.
I have tested this with various email clients and the only thing that works is outlook on a PC or webmail. My Android phone is now useless for emails.
It not the cache, not the application (tried numerous, all the same - headers and notifications but no content)
Something changed last week, so it should not be beyond whit of man/woman to identify the change and fix it - and I say this as a programmer....
Pat
Message 70 of 92
Strange that my Android phone works perfectly well with Bluemail then!
