Message 1 of 7
Email problems
In the last couple of days I have been unable to receive messages from another BT mail user (my wife) whereas previously this was never an issue. She can receive messages from me okay but when she sends me a message it appears in her sent box but I never receive it. Would this problem likely to be with my account or with hers?
Also, in the last couple of days my inbox always shows one more new email than there actually is, ie it will show as one new message but nothing there.
Finally, in the last few weeks when I have received phishing emails with attachments in my inbox  I am unable to forward them anywhere ie [email protected]. When trying to do so a pop up box appears and advises that “ We are experiencing issues with the service, please try again later”. I have contacted BT about this but the advisor that I spoke to was unable to help as she could not find the answer to the question and advised me to just delete them. This is all very well but will not eliminate the problem. I have done all the usual checks such as clearing cache and cookies and logging in from different browser and different device but nothing seems to solve the problems. Have any other users had similar problems recently, any help would be most appreciated.
6 REPLIES 6
Message 2 of 7
Re: Email problems
With regards to your wife's email address, make sure you have not blocked it.
Log onto your BTMail account using a browser, not an email client/app, and then click on your username at the right hand side. Select "Settings" then go to the left hand side and select "Mail". Scroll down and click on "Blocked Senders".
Scroll down the list until you find the one you want to unblock and select it. Click on the small "Trash" symbol at the right hand side. It will only delete the email address from the blocked senders list not your contacts list.
As regards your second problem. If they are scam emails with attachments it is little wonder that your email account will not allow you to send them. Remove and delete the attachment then try and send the email.
Message 3 of 7
Re: Email problems
I had already checked the Blocked Senders along with the other checks.
Message 4 of 7
Re: Email problems
Pity you never mentioned that as it would have saved me wasting my time!
Message 5 of 7
Re: Email problems
Meow
Message 6 of 7
Re: Email problems
Great attitude!
