Message 11 of 13
Re: Email replies to wrong address
Have you checked on your devices that use the app that there is nothing set up in the app as well as checking webmail?
Message 12 of 13
Yes, I have checked through both the app and the webmail and nothing has been set up on either. I am stumped.
Anonymous
Not applicable
Message 13 of 13
I don't use BT email or it's app but try going to Settings > Manage Accounts & go into the settings for that email address & see if there's anything untoward there.
Is this something that's just started happening or was it working previously?
Another option to consider is using a different email app.
