Message 1 of 4
Email search function
Hi,
Is there a search function within the BT email set-up?
3 REPLIES 3
Message 2 of 4
Re: Email search function
Yes. You'll find it in the menu bar and its named "Search the....  To search a specific folder, select the folder then use the search  drop down list.
Message 3 of 4
This does not work, when I try to select all folders, it's greyed out and does not allow me to perform a search on ALL folders - any other suggestions?
Message 4 of 4
You are posting on a two year old thread, which at that time was using a different BTMail UI (User Interface) and at that time it did work!
