Message 1 of 7
Email send limit
Recently my BT account was ‘secured’ because I suspect that I sent too many emails over a five-hour period and, despite a 2.5 hour online chat and a password change, the matter could not be resolved without reference to Team 2 (not quite sure who they are).  It took 48 hours for the situation to normalise.  I am anxious to avoid a repetition and therefore would appreciate knowing the email ‘send limit’ and over what period.  Can anyone help?
6 REPLIES 6
Message 2 of 7
Re: Email send limit
From a previous post the limit is 49
https://community.bt.com/t5/Email/BT-EMAIL-How-do-I-simply-send-a-message-to-all-contacts-in-the/m-p...
Message 3 of 7
Thanks imjolly for the information.  If that's the case, when I sent 480 emails in batches of 25 (sent 2nd batch when 1st had cleared my outbox, and so on) why would BT secure/lock my account due to "unusual activity" or similar?
Is there a time factor involved i.e. 49 emails in, say, a half hour period?
PeteB3
Message 4 of 7
Why on earth would you use a consumer grade ISP email to send 480 emails!!!
Message 5 of 7
Thanks licquorice. I only need to do this once or twice annually for a non-profit charity and I know how to achieve the goal using mail merge Access/Word. I've looked at Mail Chimp (free) and, although it may be my lack of familiarity, it seems slightly complex and limited. Any further observations/help would be welcome.
Message 6 of 7
I haven't used Mail Chimp personally, but I know other contributors to the forum use them successfully.
I really would consider a proper mail sender for that volume of emails.
Message 7 of 7
Thanks, licquorice.
