Message 1 of 3
Email stopped working on iphone
My email app on my iphone has suddenly stopped working. I have tried removing and adding the account back in but it is not working.  Any suggestions what to do next?  Usually removing and adding back in works but not this time.....
I'm getting the message 'The IMAP server"mail.btinternet.com" is not responding so is that a BT problem rather than a mine problem?
2 REPLIES 2
Message 2 of 3
Re: Email stopped working on iphone
It is probably a BT server problem. The best advice when it happens is to do nothing, especially do not change passwords or delete the account from your phone as that can cause more problems than it solves.
The first thing to do when it happens is check to see if you can log on to your email account via a web browser. If you can there is obviously nothing wrong with your password or account hence the advice to do nothing.
If the problem has not resolved its self after a day or two or in your instance where you have deleted the email account from your device you should stop your iPhone and any other devices from checking for email. The easiest way of doing that is to turn them off if you still have the account on your device or add a couple of characters to the email address so that it is not checking your account. If you have deleted the account and it is no longer on your device do not try and add it at this time.
Once you have done that, change your email password and check that you can access your email via webmail (on a browser).
If that works you should wait at least an hour to allow the servers to sync and then add the new password to your iPhone, remembering to remove any characters you may have added and again check it works.
When entering the settings, make sure that in the Outgoing server you do not use the "use same as incoming" for the email address and password. Enter them manually.
If the above does not resolve the problem, when you change your BT password on an iPhone/iPad/Apple device it may only change for INCOMING mail.
To change the outgoing mail password you have to go into Settings; then scroll down to Passwords & Accounts or on older devices Mail, Contacts, Calendars. From there select the BT email account and select the account where it is listed under IMAP.
You will find the details for the account and can change the password for the Incoming server there, the outgoing mail server only shows SMTP and mail.btinternet.com You have to tap on that Primary Server in order to find where the Outgoing password is hidden so you can update it.
On newer iPhones Tap Settings. Scroll to the bottom and tap Apps, then Mail. Tap Mail Accounts. Tap the appropriate account.Tap Re-enter Password and follow the steps to log in with your new password.
When setting up the email account on your device you are best to set it up manually, using "other" and ensure that you are using the correct settings as per this link.
https://www.bt.com/help/email/manage-email-account/manual-settings/what-are-the-settings-for-outgoin...
Message 3 of 3
I should have asked are you presently a BT Broadband customer or are you paying for your email through a BT Premium email account or did you migrate to EE Broadband?
If none of the above your email account may have been downgraded to a BTMail Basic account which can not be used with an email client or email apps.
See link
https://www.bt.com/help/email/bt-email-products
