Message 1 of 8
Emails keep disappearing
When I open on an email in the Mail app on my iPhone they flash and then disappear and are nowhere to be seen. I then tried to find them in the BT Email app and I can’t see them either. They are not in any of my folders or the trash. But the app says I have 12 unread emails but I can’t see them. I have lost some fairly important emails. Please can you tell me where they have gone.
7 REPLIES 7
Message 2 of 8
Re: Emails keep disappearing
Hi @emilypeirce,
Welcome to the BT Community
Are you able to locate the e-mails when logged in to BT Webmail?
When using BTMail do you have conversation view enabled? To check log onto your BTMail account and click on "View" in the menu bar at the right hand side. Then click conversation view to turn it on or off.
Alex
Message 3 of 8
Hi Alex
No they are still not there in webmail. And conversation view is not on in BTMail.
Emily
Message 4 of 8
@emilypeirce Ah ok thanks for checking that. If you check the e-mail settings for your BTMail account in your iPhone Mail app settings, can you see if your set to POP3 or IMAP? This page might be some help BT Email server settings | BT Help
As if they are appearing on your phone briefly but not anywhere within Webmail, it could be because of using POP3 rather than IMAP in your Email server settings.
Alex
Message 5 of 8
Hi Alex
It is set to IMAP currently.
thanks
Emily
Message 6 of 8
Are you sure you don't have any other device configured as POP3?
Message 7 of 8
No but I have recently got a new phone but did a factory reset on my old phone. I didn’t have this problem on that phone though. And I don’t use any other devices for my emails. It seems to be emails all relating to Weddings if that helps.
Message 8 of 8
@emilypeirce Are they all recent e-mails from a specific sender/group you mean? I would check all your settings for auto-forward, rules, blocked senders and safe senders if it is specific to see if there could be anything there.
Outside of that it may be best to give us a call for some further help Fix email | BT Help
Alex
