Message 11 of 17
Re: Emails sent via Gmail sending BCC list to BTmail addresses gets corrupted
Hi I have logged the complaint with BT service desk and they are escalating it to the Tier Two Team.
However they say it can take between 3 to 5 days to be resolved depending on the complexity of the problem.
Let's hope they can fix it ASAP.
In the mean time I'm using my btinternet.com email address to send BCC to all my contacts with btinternet.com addresses and this works fine.
Hope this helps all those with this same problem.
Message 12 of 17
Message 13 of 17
Thanks licquorice
I'll give it a week or so to make sure it's really fixed before I subject my contacts again with this problem. Apparently it caused older versions of Outlook to lock up and they could only get out of it by rebooting..... Hey Ho the joys of computing.
Message 14 of 17
I've had an email from the BT service team saying they are looking into the problem and will contact me when they have resolved it. So it may be a little premature to say they have fixed this one as it may well have been another similar problem that Licquorice  is refering to. I'll keep you posted when I get a definitive response.
Message 15 of 17
Yesterday afternoon I sent an email from the club's @gmail.com address to a selected 10 members with btinternet.com email addresses under BCC, so far 8 have replied to say "all OK". Hopefully that is the end of it but as you  say, let's see.
Message 16 of 17
Good News, I've had official confirmation today from BT technical that this issue has been resolved. Apparently, Gmail had changed something in their interface to BT without telling them. BT have now addressed the matter, and the header should not be stripped from the BCC email addresses now. So, no more corruption to emails from Gmail. Hoorah!
Message 17 of 17
That's good news, thanks for passing that on. I've got twenty members who will be relieved not to receive gobbledegook from me any more.
