Message 1 of 5
Enlarge email in iphone
When I landscape email to enlarge on my iPhone a summary of all emails appears on the left side of screen reducing the enlargement.
4 REPLIES 4
Message 2 of 5
Re: Enlarge email in iphone
It would help if you state how you are accessing your email on your iPhone. Is it with a web browser or an email client/app and if so which one?
Message 3 of 5
Hi. Thank you for your speedy reply. I have just logged in to my email from my web browser and the oddity of trying to landscape my message and finding the page half taken by the list of emails doesn’t arise. I normally log in from what I assume is the BT app. (Purple with the outline in white of an envelope on it). The new behaviour when reading emails has only been happening for a few days. I am not aware of any software updates in that time.
Message 4 of 5
If you are still getting this problem I would suggest that you consider a different email app. The BTMail one is in my opinion not very good. You could try the Bluemail email app which others on this forum have found to be good.
Message 5 of 5
Good evening. Ok. I will try that. If I get a result, I will post a reply here. Thank you for your suggestion. Best wishes. velofellow.
